Switch Account
routers
Highlighted
Message 1 of 4
(5,781 Views)
does verizon offer a modem that is set up like a router if so can someone point me in the right direction
thnx
3 REPLIES 3
Highlighted
Message 2 of 4
(5,747 Views)
Is this regarding DSL or FIOS?
Highlighted
Message 3 of 4
(5,560 Views)
VERIZON HAS TWO DIFFERENT TYPE OF MODEMS ONE IS FOR WIRELESS COMPUTERS AND ONE IS FOR DESKTOP I BELIVE THE ONE YOU MIGHT BE INTERESTED IN IS THE GATEWAY. MIGHT WANNA CALL THE FSC 8885531555 AND ASK ABOUT IT THE ONLY THING IS ITS LIKE $55 PLUS SHIPPING BUT THEY DO HAVE ONE FOR DSL IF YOU HAVE FIOS THEN WELL... YOU SHOULD HAVE A ROUTER
Highlighted
Message 4 of 4
(5,551 Views)
Yes they do they use westell and actiontec westell is not a good choice for the reason is when they heat up they like to freeze up and so doe's the actiontec m1424mr so stay away from them.
