Switch Account
Help with running Echolink ham radio software and port forwarding
Highlighted
Message 1 of 2
(5,318 Views)
I recently had to replace the router on this system.  The old one a D-Link 624 worked fine with the Echolink program.  The new router a Attiontec M1424-WR will not work with this application.  The ports have been forwarded correctly however, it is unable to make a solid connection.  Any assistance will be most appreciated.  Thanks in advance.  Bill
1 REPLY 1
Highlighted
Re: Help with running Echolink ham radio software and port forwarding
Message 2 of 2
(5,287 Views)
The problem has been resolved.  Although the Ports were forwarded correctly by the Port Forward Program, The router had to be set to operate in the DMZ area.  This action was not accomplished by the Port Forward Program.  All is working fine now.
