Customers With Disabilities
quick menu
IPad & Kindle Fire connection problems
BISERV
Message 1 of 6
(1,785 Views)
Have new Ipad and kindle fire that will not connect to internet. Both connect to wireless but when we try to go on line they will not connect. We have an old Westell 327W DSL router. Could this be the problem. Regards
Employee
Employee
Message 2 of 6
(1,722 Views)
The type of router you have shouldn't be the problem. With any wireless device you have to put in the correct WEP key (password) in order to get connected. If you are not sure what it is, log into the router and retreive it from the settings. If you need further help please reply back so any one of us can assist.
Anthony_VZ
**If someones post has helped you, please acknowledge their assistance by clicking the red thumbs up button to give them Kudos. If you are the original poster and any response gave you your answer, please mark the post that had the answer as the solution**
Notice: Content posted by Verizon employees is meant to be informational and does not supersede or change the Verizon Forums User Guidelines or Terms or Service, or your Customer Agreement Terms and Conditions or plan
CB12
Message 3 of 6
(1,598 Views)
I am having the same exact problem.  My Kindle Fire finds the network but won't sync/download or anything.  Amazon put the problem on the router, and Verizon put the problem on the Kindle.  Went to a wi-fi cafe and no problem occurred so it has to be my home router but no ownership by Verizon.  I have a WEstell router
pegasorus
Message 4 of 6
(947 Views)
i keep trying to log into my router but everytime i press a key multiple charachters show up in the password box.i'm trying to connect my apple ipad.any help would be great.
thanx
Bronze Contributor I
Message 5 of 6
(918 Views)
My understanding is that the multiple characters show up as a security feature to avoid (preclude) anyone determing how many actual characters there are in your password.  Just type in your password anyway, and you should be fine. - Provided that is the only problem
Employee
Employee
Message 6 of 6
(851 Views)
thanx
This is a security feature. It's to prevent someone from looking over your shoulder to see how many characters are in the password. Please type in your password as it is, ignoring how many characters show up on the screen.
Anthony_VZ
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Manage Services
Support
Watch Fios
