MODEM DROPS TO LOW SPEED ON PHONE RING
rick01
Message 1 of 2
(851 Views)
I am using a Westell 6100 modem.  Internet speed is normally 1.5 to 1.7 MBS.
 If the phone rings while i'm on line, the internet  speed drops below 500 K **bleep** and stays there after the call is completed.
 I need a modem power down to get the speed back up.
 Outgoing calls that I make do not affect the modem speed.
1 REPLY 1
dslr595148
Re: MODEM DROPS TO LOW SPEED ON PHONE RING
Message 2 of 2
(813 Views)
#1 Log into the modem at http://192.168.1.1/
#2 Choose System Monitoring in the navigation, Advanced Monitors from the Left Hand Side Navigation and then choose System Logging. Post up the contents of the "All" log, either via pastebin.com or via Copy and Paste (Pastebin is preferred since it helps to keep the thread tidy looking). Additionally, post up your modem's Transceiver Statistics (found in the Advanced Monitors section as well) which you can Copy and Paste into the post here.
* -> If you need a Username and Password, try:
admin/password
admin/password1
admin/admin
admin/admin1
