Replaced modem but again same problem
cat1
Message 1 of 14
(8,984 Views)
Hi, I do not know what to do.
When I switched to werizon DSL internet the first two months the internet was OK, but after the light for the internet on my modem- westell 7500 started to turn red, and some times just off color. Initially the switch off/on helped but after some time the internet was not available in the most of the time. I called several times to the technical support but after hours, talking and switching...the problem stayed the same. In the end, we decided to replace the modem, BUT here after 1 week the internet is again almost not available. I tried to connect with another modem (from friend with werizon internet modem (the model is westell 6100F) and after few minutes the light for the internet turned off. I do not know what it can be?! If it helpful, we have home phone connected with werizon that works well.
Can any body help?
Thanks.
13 REPLIES 13
Telcoguru
Re: Replaced modem but again same problem
Message 2 of 14
(8,968 Views)
Please post your modem stats.
cat1
Message 3 of 14
(8,962 Views)
The modem is westell 7500  model A90-750015-07
dslr595148
Message 4 of 14
(8,946 Views)
Ok, we can try it this way..
I found some screens of this modem.
http://www.lava.net/support/Westell_2200_DSL_Modem_Installation_Guide
If your modem screens, look like that go to the trouble shootinglink.
In there, there should be something about modem stats..
The screen that you see may look something like the screens at the following URL
http://www.dslreports.com/speak/slideshow/21324006?c=1362921&ret=L2ZvcnVtL3JlbWFyaywyMTMxMDk3OA%3D%3D
cat1
Message 5 of 14
(8,909 Views)
Hi, thanks for the help.
The  link http://192.168.1.1 don't show any problem. Now works but how long?!
cat1
Message 6 of 14
(8,889 Views)
Today my modem do not work again......I will try with another provider, but our contract is for a year......What a mess.......
Telcoguru
Message 7 of 14
(8,879 Views)
I asked you to post your modem stats not the make and model of your modem. The modem stats show what the download and upload speeds of your modem are currently at.
bdbauer
Message 8 of 14
(8,875 Views)
I have the same or similar issue. I have had 4 Verizon technicians out, I have been on the phone for over 8 hours with tech support. They sent me a new modem today and still the same issue.
The modem is a westell 7500, If i go into the modem and see the down/up speed it says 864/160. However my connection is super slow. Speedtests at  infospeed.verizon.net, speedtest.net, and speakeasy all come back with about the same result, somewhere between 130 - 220 download and 130 upload.
I thought it may have something to do with my computer settings, but it is not the case. I have deleted any programs that I didn't need (i even had a computer share with a verizon technician and he couldn't do anything).  If i connect to my neighbors connection it goes super fast and the speed tests come back with resuls at 1865/864.
Please help!Man Mad
Telcoguru
Message 9 of 14
(8,873 Views)
What are your noise margins at?
bdbauer
Message 10 of 14
(8,870 Views)
where wouldsee that at?
Modal Dialogue Title
