I have a Westell 327W that I have been using since 2007 and have a couple of computers connected wirelessly to it. At random times, none of the computers can communicate with the Westell, even though all the lights were flashing normally. If the computer was already connected, you could not even get to the router page. If you were trying to connect, the Westell would not establish a connection. If I did a power reset, then everything would work again. It was as though the firmware got itself into an infinite loop.
At first this would happen a few times a year. Then it went to a few times a month. Finally last week, it was several times a day, with one time taking three power resets to get it to work again, only to have it go out a few hours later.
Well, I figured some part in the Westell was failing. I happen to have a barely used Actiontec GT704-WG with the Verizon firmware which I also got in 2007. So I switched gateways.
One day later, I got the same wireless connection problem. Now this is a new gateway, different manufacturer, different firmware.
Anybody have any ideas what is going on?
While you are on DSL, you may find this other thread interesting / useful.
http://forums.verizon.com/t5/FiOS-Internet/Why-your-Wi-Fi-is-slow/td-p/534451
Thanks, but the wireless connection doesn't slow down when I have the problem, it dies and doesn't come back. Also I have no wireless phones and my house is of which I am the only occupant is separated by a interval from other houses.
Are you suggesting that some sort of interference can knock out the router's internal programming (firmware)?
That would be correct.
