Switch Account
Deleting Door Lock Codes - Not working
Nickel Contributor
Nickel Contributor
Message 1 of 5
(1,953 Views)
My device setting isn't letting me delete door lock codes after the first code. Only edit is available. The last code has a delete. Any suggestions? Thx!
4 REPLIES 4
Silver Contributor I
Message 2 of 5
(1,932 Views)
I don't have a door lock but my programming experience makes me think that once a code is set, it can be edited but not deleted.
What if you delete it from your system altogether? That may also reset the device and flash the code back to a null setting.
Message 3 of 5
(1,931 Views)
Sorry, when I say "delete it" I mean the device itself.
Nickel Contributor
Nickel Contributor
Message 4 of 5
(1,922 Views)
That's not the answer because I can create other pin #'s and delete them
Message 5 of 5
(1,898 Views)
If this is the MASTER PIN and there are no other PINs, then it may not allow you to delete it, only change it. In other words, the lock MUST have at least one (1) PIN to operate. Again, I'm just guessing based on my knowledge of other systems of this type.
