Switch Account
Direct Number for Verizon Home Monitoring & Control ?
Silver Contributor I
Message 1 of 4
(1,601 Views)
What is the direct phone number for Verizon Home Monitoring & Control?
When I call tech support it takes several transfers to get to a HM&C tech.
3 REPLIES 3
Moderator Moderator
Moderator
Message 2 of 4
(1,594 Views)
Please check your Private Message Inbox. It should look like this -->>
If a forum member gives an answer you like, give them the Kudos they deserve. If a member gives you the answer to your question, mark the answer that solved your issue as the accepted solution.
Message 3 of 4
(1,496 Views)
Great, so the phone number we have been given is 866-657-1618.
Thank you
Message 4 of 4
(1,397 Views)
Well, it looks like that phone number is no longer good. It now goes to Plum Choise Tech Support and they say they don't support Verizon HM&C.
