Switch Account
Energy Reader not reading
SOLVED
Contributor suzmoss
Message 1 of 5
(1,819 Views)
My energy reader stopped getting readings about a month ago and I have not been able to get it back.  I a little nervous about troubleshooting something that is in my electrical box.  Suggestions?
4 REPLIES 4
Contributor dflags
Message 2 of 5
(1,776 Views)
If you had the reader installed professionally, then I would call the installer to have them check on their work.  Prior to that you should check to see that the reader is plugged into a working outlet and that it is showing as working in the system.
Contributor Bob468
Message 3 of 5
(1,722 Views)
1. The reader will not transmit through the metal box.
2. Call a professional.
3.  Don't touch anything in the box that is metal.
4. Move the reader out of box and mount on wall & add it to the system again.
Contributor suzmoss
Message 4 of 5
(1,648 Views)
Thanks  It was installed by Instalnet as part of the original installation.  I will have to call them back.
Bronze Contributor I
Message 5 of 5
(1,591 Views)
Did you actually get this solved or was it just marked that way? I am having the same problem. If you found some way to make it start reading again I would be interested. Thanks.
