Gateway not responding - need to reset all zwave devices
SOLVED
photosbynick
Copper Contributor
Copper Contributor
Message 1 of 4
(8,786 Views)
Out of nowhere, my gateway will not respond. I can login using the app on my iphone, on the computer or with the tv but when I try and turn lights on or off, it wont let me. It wont shot my thermostat either.
I think the gateway is dead. If this is so, then there is no way for me to reset my zwave devices because you need the primary controller to remove them from the network in order to allow them to be used on a new network.
Someone help.
1 ACCEPTED SOLUTION
Accepted Solutions
photosbynick
Copper Contributor
Copper Contributor
Re: Gateway not responding - need to reset all zwave devices
Message 3 of 4
(8,748 Views)
OK and its fixed. What we did.
1. Unplugged gateway for 12 hours.
2. Plugged back in and let sit for an hour.
3. logged in on phone and it worked.
4. Deactivated all of the devices on the account.
5. cancelled the account.
Moved all devices to IRIS and works flawlessly!!!!
3 REPLIES 3
shaenn
Silver Contributor I
Message 2 of 4
(8,764 Views)
Most likely it is not you, it's the currect issue that Verizon is having. See my many posts in the following thread:
http://forums.verizon.com/t5/Home-Monitoring-and-Control/HM-amp-C-Camera-Recordings-Not-Viewable/td-...
Call tech support at 866-785-8153 (direct line to VHM&C) and report your problem. Please post back here when you know what's happening.
photosbynick
Copper Contributor
Copper Contributor
Message 3 of 4
(8,749 Views)
shaenn
Message 4 of 4
(8,727 Views)
Well, that's one way to solve the problem. Good for you!
