reprograming door lock
shymedq
Nickel Contributor
Nickel Contributor
Message 1 of 4
(2,953 Views)
so I no longer have fios but I paid for the door lock so how do I reprogram the numbers to something else without going on verizon website anyway to do it on the lock it self?
3 REPLIES 3
Lew_D_Vz
Employee Emeritus
Re: reprograming door lock
Message 2 of 4
(2,927 Views)
Insturctions for local programming of your door locks are available on the Internet as follows:
Dead Bolt Door Lock: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Lever Door Lock: http://consumer.schlage.com/Project%20Documents/P515-859.pdf
shymedq
Nickel Contributor
Nickel Contributor
Message 3 of 4
(2,915 Views)
i cant get the lock to reprogram or change the key it says press (pc) then schlage button but what is pc button?
perlinef
Message 4 of 4
(2,744 Views)
The PC refers to the Programming Code. You can find it by opening the lock--taking it off the door; there should be a sticker with that info. The lock comes with a preset programming code and user code (UC)--unless you changed it. In that case, you can reset to the factory code by taking out the  battery, press "Schlage" put the battery back in, then press and hold "Schlage." At least that's how my lock works.
Modal Dialogue Title
