Customers With Disabilities
quick menu
How do I block incoming calls from specific phone numbers?
chrisnmiandrews
Message 1 of 2
(2,414 Views)
I have Fios digital voice.  I would like to block specific incoming calls from specific phone numbers.  I have tried to research this using the Verizon In-Home Agent but couldn't find the answer.
Any specific help would be appreciated!
1 REPLY
Silver Contributor IV
Message 2 of 2
(2,375 Views)
If you log into your FIOS Digital Voice Account either through my.verizon.com or www.verizon.com/fiosvoice
Select Calling Features
Incoming Call Block
Reject calls from Certain Numbers
Then enter up to 10 phone numbers you want to block.
Jim
My Rewards+
Start earning points Enrolling in My Rewards+ is quick, free and easy
Refer A Friend
Refer friends to the Verizon Fios Family, and earn 10,000 My Rewards+ points
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Manage Services
  • Apps
Support
Watch Fios
