Customers With Disabilities
quick menu
Verizon Home Phone Connect problems
lcdrdan
Message 1 of 3
(8,611 Views)
I recently purchased the Home Phone Connect unit from Verizon.  It consists of a device for residential phone service.  The instruction book shows simple connections....power and phone cable only.  It was connected as shown in the manual, and all lights are on....MESSAGE LIGHT:  BLINKING,      POWER LIGHT:  ON,       BATTERY LIGHT:  CHARGED  , and TWO SIGNAL LEVEL LIGHTS:  ON (indicating a strong signel).              When I try to make a call....I immediately get a busy signal.  i cannot receive any calls....(incoming calls go immediately to messages (thats why the message light in always blinking).    I've talked to  Verizon technicians twice....but not results.   One Technician said that i do not need the power cable connected....only the phone cable.  (while this does not make sense, I tried it and of course, I didn't even get a dial tone).     Another technician suggested that I dial "1" before each number.....again no change.
Has anyone had troubles getting their Home PHone Connect system to work.....  I would appreciate any help.
Thanks in advance.
lcdrdan
Employee
Employee
Message 2 of 3
(8,532 Views)
I'm sorry to hear about the problem your having with your phone. Are these the only phones in the house? If not, please unplug them and test to make sure the line works as it should before plugging the Home Phone Connects back in.
Anthony_VZ
**If someones post has helped you, please acknowledge their assistance by clicking the red thumbs up button to give them Kudos. If you are the original poster and any response gave you your answer, please mark the post that had the answer as the solution**
Notice: Content posted by Verizon employees is meant to be informational and does not supersede or change the Verizon Forums User Guidelines or Terms or Service, or your Customer Agreement Terms and Conditions or plan
Platinum Contributor II
Message 3 of 3
(8,373 Views)
This is Verizon Wireless's product, but it sounds like this should be a pretty simple fix. If the Wireless telephone device has already been provisioned by Verizon Wireless, if you were to unplug the device from your telephone wiring, do your phones still give a busy signal or some other form of connection, or are they completely dead? Have you ensured any existing landline service, such as a POTS line with Verizon or an old Cable modem VoIP service have been completely disconnected from your home's wiring? Does the Home Phone Connect service work when you plug a phone directly into the device?
My Rewards+
Start earning points Enrolling in My Rewards+ is quick, free and easy
Refer A Friend
Refer friends to the Verizon Fios Family, and earn 10,000 My Rewards+ points
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Manage Services
  • Apps
Support
Watch Fios
