I used to have to press the STB and TV power buttons separately to turn on and off the TV's and set top boxes and now just pressing the STB button turns on both. If someone goes to turn them off and hits the TV power first and then the STB, the TV turns back on. Gets confusing when they get out of synch. Are there any settings on the remote or TV that would reset this to the way it used to work, pressing each one seperately?
Correct answers
Follow these instructions...
OPTIONAL FEATURES <STB Power> Button Turns on TV and STB
Your remote has separate power buttons for the TV and STB. You can program the
key to turn on/off both your TV and STB at the same time.
1. Turn both your TV and STB on.
2. Press and hold the <OK> and buttons together, then release both.
• The RED LED will blink twice and then stay on.
3. Press9–7–7.
twice and remain on.
4. Press .
• The RED LED will blink 3
times and then turn off. 5. Test that the key
now turns on the TV and STB at the same time.
6. If you want to reset the remote so that the controls Only the STB, follow the same steps as above but press <OK> in Step 4.
Here is a link to the instructions...
https://www.verizon.com/home/accessories/media/images-accessories/productPDF/P265_brochure.pdf
3. Press9–7–7.
4. Press .
Thanks!
