Problems Programming P265 Remote for Vizio TV
SOLVED
airjay81
Copper Contributor
Copper Contributor
Message 1 of 3
(3,335 Views)
So, my remote was working fine with my TV until about a day ago.  All of a sudden, it stopped working.  I have been trying to reprogam it.  I have used the code method and search method all to no avail.  I just can't seem to get it programmed.  Maybe I am just an idiot and am not doing the key sequence correctly, but I think I am a reasonably intelligent person.  Any thoughts on where I might be going wrong?
1 ACCEPTED SOLUTION
Accepted Solutions
airjay81
Copper Contributor
Copper Contributor
Re: Problems Programming P265 Remote for Vizio TV
Message 2 of 3
(3,323 Views)
Nevermind.  I finally got it to work.  Please disregard.
2 REPLIES 2
airjay81
Copper Contributor
Copper Contributor
Message 2 of 3
(3,324 Views)
airjay81
Copper Contributor
Copper Contributor
Message 3 of 3
(3,321 Views)
As an FYI, when doing the search method, I think my problem was that I hadn't waited long enough for the remote to go out of programming mode, so when I did the search method, and got to the point of pressing play, it was not doing the code search.  I waited a good minute or two, and then started the search process over, and I finally got it to work.  The second or third code tried worked.
Modal Dialogue Title
