Remote DVR problem !!
threepac3
Enthusiast - Level 2
Hi,
I have 2 DVR boxes in my home one is SD and the other is an HD one. My problem is that I have activated th SD box for remote play but see no way to activate the HD box. I can see that there is a forwarding entry in the router for the SD box as well. AM I missing something obvious or is there a problem? Thank you.
~3pac
Re: Remote DVR problem !!
spacedebris
Master - Level 2
When you say "remote play" do you mean the ability for a non-dvr to watch the recorded programs?
If so that is because only one DVR can be desigated as the MR-DVR. (HUB). you cannot have more than one hub, at least at this time. So you can select the SD dvr as the hub or the HD dvr as the hub. but not both
Serpo
I have a FIOS HD DVR box. How do I do the remote DVR thing. Seems like a nice feature. I only wish they had an App on the iphone like direct tv.
Serpo
I figured it out, very cool feature.
