TV remote code for Dynex does not provide full functionality.
margokw15
Re: TV remote code for Dynex does not provide full functionality.
Message 11 of 17
(1,855 Views)
So I should try the remote I know works? It was at my previous apartment and I already returned it, which I regret.
I will consider asking for a new remote at a Verizon store. Is there a difference between the store you are referring to an a Verizon Wireless store? I know the services are very separated so that's why I ask.
bob428
Copper Contributor
Copper Contributor
Message 12 of 17
(1,851 Views)
Once you find the correct code be sure to write it down somewhere convenient.  I use the inside of the battery compartment.  This way if you need to reprogram it, you will have the correct code.
armond_in_nj
Gold Contributor IV
Gold Contributor IV
Message 13 of 17
(1,843 Views)
@margokw15 wrote:
 ... Is there a difference between the store you are referring to an a Verizon Wireless store? I know the services are very separated so that's why I ask.
Yes, there is a difference.  Try this link:
http://www22.verizon.com/home/storelocator/
margokw15
Message 14 of 17
(1,837 Views)
Thanks! Glad I asked!
Hubrisnxs
Platinum Contributor III
Message 15 of 17
(1,828 Views)
you can also order a remote in the set top box menu
just hit menu>customer support>in home agent>order new remote.
RVC
Message 16 of 17
(529 Views)
This just worked for me thank you.
LawrenceC
Moderator Moderator
Moderator
Message 17 of 17
(520 Views)
Modal Dialogue Title
