HELP HAZARD BROKEN Fios Utility Box
SarahH4
The FIOS Utility box set in my lawn has a broken cover and water is pouring down into it.  It is also sinking into my yard.  Please advise how this can be fixed ASAP.
Thank you.
Sarah
Re: HELP HAZARD BROKEN Fios Utility Box
LawrenceC
Moderator Emeritus
Hi SarahH,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary and may be delayed at this time. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
